Inleiding
Loaded programs and data in a computer are stored in temporary memory known as RAM. Most commonly, you would replace the RAM as a means of upgrade, whether it be faster speeds or more space.
Please keep in mind that due to the limitations of this laptop, the RAM has a maximum size constraint of 8GB.
Wat je nodig hebt
Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
Use the black plastic spudger to remove the battery from the device.
Pay attention to the different lengths of the screws
hugodevreugd - Antwoord
