Ga door naar hoofdinhoud
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
Wat je nodig hebt
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: stap 1, afbeelding 1 van 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: stap 2, afbeelding 1 van 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: stap 3, afbeelding 1 van 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: stap 3, afbeelding 2 van 2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: stap 4, afbeelding 1 van 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: stap 4, afbeelding 2 van 2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: stap 5, afbeelding 1 van 1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Conclusie
Mark Fanelli
97 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G2, Hovde Spring 2019 Lid van IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 421
