Inleiding
If your ASUS VivoBook S400C hard drive is making clicking and humming sounds, or if your programs are repeatedly crashing, use this guide to replace your hard drive. Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Note: As this is a 2.5” hard drive, if you are looking to replace this hard drive be sure to get one that is 2.5”s.
Wat je nodig hebt
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
Remove the three Phillips #0 screws holding the the hard drive in place:
Two 3.8 mm screws.
One 5.7 mm screw.
