Inleiding
Use this guide to replace the complete display assembly as a unit, consisting of the display housing, hinges, WiFi and display cables, LCD, touch screen and front bezel, as well as the interior electronics (microphone, camera and touchscreen controller).
In most cases this would only be done if you've purchased a used display complete and only need to swap out the display without having to open it to get to the LCD or touch screen.
Wat je nodig hebt
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Remove the black shield covering the display connector and the heat sink.
Remove the black tape securing the keyboard ribbon cable to the display connector.
Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
Remove the two screws securing the hinge on the left.
Pry the hinge up by hand to a 90 degree angle.
Lift the base of the laptop from the front.
Raise it to a 90 degree angle.
Slide it forward slightly to clear the hinges.
The display is now free.
