Ga door naar hoofdinhoud
ASUS VivoBook S400C CPU Fan Replacement
Wat je nodig hebt
  1. ASUS VivoBook S400C CPU Fan Replacement, Remove the Bottom Cover: stap 1, afbeelding 1 van 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C CPU Fan Replacement: stap 2, afbeelding 1 van 2 ASUS VivoBook S400C CPU Fan Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C CPU Fan Replacement, Disconnect the Battery: stap 3, afbeelding 1 van 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: stap 4, afbeelding 1 van 2 ASUS VivoBook S400C CPU Fan Replacement, Heat Shield: stap 4, afbeelding 2 van 2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: stap 5, afbeelding 1 van 3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: stap 5, afbeelding 2 van 3 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan / Heat Sink Assembly: stap 5, afbeelding 3 van 3
    • Unplug the fan.
    • Grasp the plug with a fingernail on either side and pull it straight out from the connector.
  6. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink Screws: stap 6, afbeelding 1 van 1
    • Remove the two 5 mm screws securing the fan.
    • Remove the four 3 mm screws securing the heat sink.
    • Removing the screw covered by the warning label will void your warranty.
  7. ASUS VivoBook S400C CPU Fan Replacement, Remove the Fan and Heatsink: stap 7, afbeelding 1 van 1
    • Lift the fan and heatsink straight up to remove it.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
  8. ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: stap 8, afbeelding 1 van 2 ASUS VivoBook S400C CPU Fan Replacement, CPU Fan: stap 8, afbeelding 2 van 2
    • Flip the assembly over and peel off the tape wrapped around the edge of the fan.
  9. ASUS VivoBook S400C CPU Fan Replacement: stap 9, afbeelding 1 van 3 ASUS VivoBook S400C CPU Fan Replacement: stap 9, afbeelding 2 van 3 ASUS VivoBook S400C CPU Fan Replacement: stap 9, afbeelding 3 van 3
    • Starting at one end, carefully peel off the tape securing the heatsink to the lip of the fan.
  10. ASUS VivoBook S400C CPU Fan Replacement: stap 10, afbeelding 1 van 1
    • Separate the fan from the heatsink.
  11. ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: stap 11, afbeelding 1 van 2 ASUS VivoBook S400C CPU Fan Replacement, Clean the Heatsink: stap 11, afbeelding 2 van 2
    • Clean the old thermal paste off the heatsink until it is spotless.
  12. ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: stap 12, afbeelding 1 van 2 ASUS VivoBook S400C CPU Fan Replacement, Clean the CPU: stap 12, afbeelding 2 van 2
    • Carefully remove the old thermal paste from the CPU. It is not vital to get the old paste off the parts of the chip under the Kapton tape, but be obsessive about cleaning the silicon chip itself and the area immediately next to it.
    • Do not fail to apply new thermal paste to the processor before reinstalling the heatsink. Failure to do so could lead to overheating and the possible death of your processor.
Conclusie
Jerry Wheeler
57.875 Reputatie
69 handleidingen geschreven
Oregonians Lid van Oregonians
Community
7 Leden
176 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 378
