Ga door naar hoofdinhoud
ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement
Wat je nodig hebt
  1. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  5. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 1
    • Carefully slide the card out of its connection port by pulling it outward.
  6. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Conclusie
Keith Rachels
595 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G4
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 517
