Ga door naar hoofdinhoud
ASUS VivoBook S300C Hard Drive Replacement
Wat je nodig hebt
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: stap 1, afbeelding 1 van 1
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: stap 2, afbeelding 1 van 1
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: stap 3, afbeelding 1 van 2 ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: stap 3, afbeelding 2 van 2
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Cameron
10.353 Reputatie
1 Handleiding geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.532 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 3,495
