Ga door naar hoofdinhoud
ASUS VivoBook Flip TP501U WiFi Card Replacement
Wat je nodig hebt
  1. ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: stap 1, afbeelding 1 van 2 ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: stap 1, afbeelding 2 van 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: stap 4, afbeelding 1 van 3 ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: stap 4, afbeelding 2 van 3 ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: stap 4, afbeelding 3 van 3
    • Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
    • Disconnect the card from the motherboard by pulling down on the card.
    • Unplug the two black and white wires from the bottom of the card. They should pop off.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 696
