Ga door naar hoofdinhoud
ASUS U57A-BBL4 Front Panel Assembly Replacement
Wat je nodig hebt
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 2, afbeelding 1 van 1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 3, afbeelding 1 van 1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: stap 4, afbeelding 1 van 2 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: stap 4, afbeelding 2 van 2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 7, afbeelding 1 van 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 7, afbeelding 2 van 2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 8, afbeelding 1 van 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 8, afbeelding 2 van 2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 9, afbeelding 1 van 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 9, afbeelding 2 van 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: stap 9, afbeelding 3 van 3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
Conclusie
Isabella Bernardi
671 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Lid van UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 199
