Ga door naar hoofdinhoud
ASUS U57A-BBL4 Display Assembly Replacement
Wat je nodig hebt
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: stap 4, afbeelding 1 van 3 ASUS U57A-BBL4 Display Assembly Replacement: stap 4, afbeelding 2 van 3 ASUS U57A-BBL4 Display Assembly Replacement: stap 4, afbeelding 3 van 3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: stap 5, afbeelding 1 van 2 ASUS U57A-BBL4 Display Assembly Replacement: stap 5, afbeelding 2 van 2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: stap 6, afbeelding 1 van 2 ASUS U57A-BBL4 Display Assembly Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Isabella Bernardi
671 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Lid van UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 274
