Inleiding
Use this guide to replace your camera assembly that holds the webcam. This is a fairly easy replacement just keep in mind parts of the computer are fragile.
Wat je nodig hebt
Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
Unscrew the two 3mm Phillips screws on the bottom of the frame with the J1 screwdriver.
Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
Continue to pry with the opening tool or use your fingers until the top portion of the frame releases.
Één andere persoon heeft deze handleiding voltooid.
