Ga door naar hoofdinhoud
ASUS U46E-RAL7 Audio Board Replacement
Wat je nodig hebt
  1. ASUS U46E-RAL7 Audio Board Replacement, ASUS U46E-RAL7 Back Panel Removal Guide: stap 1, afbeelding 1 van 1
    • Remove two (2) 9mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove two (2) 7mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove six (6) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove three (3) 3mm x 3mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm screws with the size 0 Phillips head screwdriver.
  2. ASUS U46E-RAL7 Audio Board Replacement: stap 2, afbeelding 1 van 2 ASUS U46E-RAL7 Audio Board Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the rubber caps (4) with the tweezers. If the rubber caps are not removed easily, pull gently. The caps are glued down.
    • Remove four (4) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
  3. ASUS U46E-RAL7 Audio Board Replacement: stap 3, afbeelding 1 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 3, afbeelding 2 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 3, afbeelding 3 van 3
    • Remove the L shaped panel with the plastic opening tool by inserting it into the indent along the USB port side of the laptop.
    • Push down gently on the plastic opening tool until part of the panel pops up.
    • Use your fingers to pop the panel off.
  4. ASUS U46E-RAL7 Audio Board Replacement: stap 4, afbeelding 1 van 1
    • Remove three (3) 5mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm (closest to the battery) screw with the size 0 Phillips head screwdriver.
  5. ASUS U46E-RAL7 Audio Board Replacement: stap 5, afbeelding 1 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 5, afbeelding 2 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 5, afbeelding 3 van 3
    • Remove the CD ROM drive by inserting the plastic opening tool between the drive and the laptop's side.
    • Push down gently to eject the drive.
    • Pull the drive straight out to remove the part from the laptop.
  6. ASUS U46E-RAL7 Audio Board Replacement: stap 6, afbeelding 1 van 1
  7. ASUS U46E-RAL7 Audio Board Replacement: stap 7, afbeelding 1 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 7, afbeelding 2 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 7, afbeelding 3 van 3
    • Flip the device so that the laptop will open away from you to remove the hinge cover behind the screen.
    • Place index fingers underneath the hinge cover and gently pull up.
    • The cover will pop off easily with a click.
    • Remove five (5) 5mm x 4mm screws from the hinge compartments of the device with the size 0 phillips head screwdriver.
  8. ASUS U46E-RAL7 Audio Board Replacement: stap 8, afbeelding 1 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 8, afbeelding 2 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 8, afbeelding 3 van 3
    • Open the screen.
    • Carefully lift the keyboard panel. The keyboard will be attached to the motherboard by two ribbons.
    • To disconnect the ribbons, use your fingernails to push down gently on the protruding plastic at the base of the connector. There is a soft click and ribbon releases. Repeat for the other ribbon.
  9. ASUS U46E-RAL7 Audio Board Replacement: stap 9, afbeelding 1 van 2 ASUS U46E-RAL7 Audio Board Replacement: stap 9, afbeelding 2 van 2
    • Remove the keyboard from the computer to reveal the motherboard.
  10. ASUS U46E-RAL7 Audio Board Replacement, Audio Board: stap 10, afbeelding 1 van 1
    • Remove one (1) 5mm x 4mm screw with the size 0 Phillips head screwdriver.
  11. ASUS U46E-RAL7 Audio Board Replacement: stap 11, afbeelding 1 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 11, afbeelding 2 van 3 ASUS U46E-RAL7 Audio Board Replacement: stap 11, afbeelding 3 van 3
    • Pull up on the black ribbon connection on the audio board. The board will lift out of the device casting.
  12. ASUS U46E-RAL7 Audio Board Replacement: stap 12, afbeelding 1 van 2 ASUS U46E-RAL7 Audio Board Replacement: stap 12, afbeelding 2 van 2
    • Using both hands pull the audio board out by pulling towards the center of the device and then up to remove.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 239
