Ga door naar hoofdinhoud
ASUS U30SD-XA1 RAM Replacement
Wat je nodig hebt
  1. ASUS U30SD-XA1 RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Before removing the RAM, shut down your laptop and unplug the power adapter.
    • Turn the laptop over onto a flat surface.
  2. ASUS U30SD-XA1 RAM Replacement: stap 2, afbeelding 1 van 1
    • At the top center on the back of the device, you will see a small square panel.
    • Use a Phillips screwdriver to remove two screws located on the panel.
  3. ASUS U30SD-XA1 RAM Replacement: stap 3, afbeelding 1 van 2 ASUS U30SD-XA1 RAM Replacement: stap 3, afbeelding 2 van 2
    • Ground yourself from electrostatic discharge by touching any metal objects or use your anti-static gloves.
    • System memories are very sensitive to static electricity.
    • Push apart the latches on either side of the slot that hold the RAM in place, but gently.
    • Use firm pressure as needed. You will hear the RAM pop out of the slot.
    • Take the RAM stick out carefully, and set it aside on an anti-static surface.
  4. ASUS U30SD-XA1 RAM Replacement: stap 4, afbeelding 1 van 1
    • To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
    • Make sure your hands are clean and do not let your fingerprints get on the memory.
    • Line up the top corners of the new RAM with the top edges of the now empty panel.
    • Slide the RAM into the slot until it's firmly in place.
    • Once you hear the RAM stick click into place, you'll know you did it correctly.
    • Now just screw the panel door back on and you're finished!
Conclusie
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
Julie M Paul
164 Reputatie
1 Handleiding geschreven
Texas Tech, Team 3-1, Rauch SU 2015 Lid van Texas Tech, Team 3-1, Rauch SU 2015
TTU-RAUCH-SU15S3G1
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 48
Altijd: 1,401
