Inleiding
This circuit board is directly connected to the USB receivers and is responsible for reading information from USB drives as well as writing information on to USB drives. This board also contains the buttons for power and volume control.
Wat je nodig hebt
Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
Using a heavy-duty spudger, pry the back cover up from the frame and completely remove.
