Ga door naar hoofdinhoud
ASUS TUF Gaming FX505DY Wi-Fi Card Replacement
Wat je nodig hebt
  1. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Solid State Drive: stap 5, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Solid State Drive: stap 5, afbeelding 2 van 2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 6, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 6, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 6, afbeelding 3 van 3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 7, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 7, afbeelding 2 van 2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
  8. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Wi-Fi Card: stap 8, afbeelding 1 van 1
    • Remove the tape covering the Wi-Fi card.
  9. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 9, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 9, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using ESD-safe tweezers, remove the two coaxial antennas by lifting up on the wires near the connectors.
  10. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 10, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 10, afbeelding 2 van 2
    • Remove the 6 mm screw using a Phillips #1 screwdriver.
  11. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 11, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: stap 11, afbeelding 2 van 2
    • Remove the Wi-Fi card by pulling it straight away from its slot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Benyamin Claxton
776 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 514
Altijd: 10,083
