Ga door naar hoofdinhoud
ASUS TUF Gaming FX505DY Speakers Replacement
Wat je nodig hebt
  1. ASUS TUF Gaming FX505DY Speakers Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Speakers Replacement: stap 2, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Speakers Replacement: stap 3, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Speakers Replacement: stap 4, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Speakers Replacement, Battery: stap 5, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: stap 5, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: stap 5, afbeelding 3 van 3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Speakers Replacement: stap 6, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 6, afbeelding 2 van 2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Speakers Replacement: stap 7, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Speakers Replacement: stap 7, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Speakers Replacement: stap 7, afbeelding 3 van 3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Speakers Replacement: stap 8, afbeelding 1 van 1
    • Lift the battery up out of the computer.
  9. ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: stap 9, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: stap 9, afbeelding 2 van 2
    • Lift the speakers from the pegs holding them down. Use minimal force as to not break the pegs or the speakers.
  10. ASUS TUF Gaming FX505DY Speakers Replacement: stap 10, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 10, afbeelding 2 van 2
    • Identify the place where the speaker cable connects to the motherboard. The port should be "SPK"
  11. ASUS TUF Gaming FX505DY Speakers Replacement: stap 11, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Speakers Replacement: stap 11, afbeelding 2 van 2
    • Pull the cable off the motherboard using a plastic pick or other pointed item and remove the speakers.
Conclusie
Nick Pearcy
313 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Harley Spring 2023 Lid van IUPUI, Team 2-3, Harley Spring 2023
IUPUI-HARLEY-S23S2G3
3 Leden
Één opmerking
model for the speaker. I want to buy a replacement , which one should I buy . I cant get original.
albert enstine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 509
