Ga door naar hoofdinhoud
ASUS TUF Gaming FX505DY RAM Replacement
Wat je nodig hebt
  1. ASUS TUF Gaming FX505DY RAM Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY RAM Replacement: stap 2, afbeelding 1 van 2 ASUS TUF Gaming FX505DY RAM Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY RAM Replacement: stap 3, afbeelding 1 van 2 ASUS TUF Gaming FX505DY RAM Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY RAM Replacement: stap 4, afbeelding 1 van 2 ASUS TUF Gaming FX505DY RAM Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY RAM Replacement, RAM: stap 5, afbeelding 1 van 2 ASUS TUF Gaming FX505DY RAM Replacement, RAM: stap 5, afbeelding 2 van 2
    • Pull the motherboard clips away from the sides of the RAM chip.
    • The RAM chip will pop up at an angle.
  6. ASUS TUF Gaming FX505DY RAM Replacement: stap 6, afbeelding 1 van 1
    • At an angle, gently but firmly pull the RAM chip to remove it from the slot.
    • To install RAM, insert the RAM into the slot and press flat until the clips make an audible "click."
Conclusie
Carter Owen
169 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 971
