Ga door naar hoofdinhoud
ASUS TUF Gaming FX505DY Keyboard Replacement
Wat je nodig hebt
  1. ASUS TUF Gaming FX505DY Keyboard Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 2, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 3, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 4, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Keyboard Replacement, Display Assembly: stap 5, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Display Assembly: stap 5, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Display Assembly: stap 5, afbeelding 3 van 3
    • Disconnect the white and black wires from the Wi-Fi chip
  6. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 6, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 6, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the white and black wires from the black tape.
  7. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 7, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 7, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Unhinge and pull the display cable from the mother board.
    • The port should be labeled "LVDS" and located between the cooling fan and the hard drive.
  8. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 8, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 8, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 8, afbeelding 3 van 3
    • Unscrew and lift the hinge.
    • Some hinges may be tough to pull, proceed with caution.
  9. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 9, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Unhinge the other side, and remove the display from the rest of the computer.
  10. ASUS TUF Gaming FX505DY Keyboard Replacement, Speakers: stap 10, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement, Speakers: stap 10, afbeelding 2 van 2
    • Lift the speakers from the pegs holding them down. Use minimal force as to not break the pegs or the speakers.
  11. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 11, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Identify the place where the speaker cable connects to the motherboard. The port should be "SPK"
  12. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 12, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 12, afbeelding 2 van 2
    • Pull the cable off the motherboard using a plastic pick or other pointed item and remove the speakers.
  13. ASUS TUF Gaming FX505DY Keyboard Replacement, Motherboard: stap 13, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Motherboard: stap 13, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Motherboard: stap 13, afbeelding 3 van 3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  14. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 14, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 14, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 14, afbeelding 3 van 3
    • Gently remove all power cables connecting the fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
  15. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 15, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 15, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm screws.
    • Disconnect the primary connector cable located at the bottom left and carefully remove the module.
  16. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 16, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 16, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 16, afbeelding 3 van 3
    • Removing the ram, push down unto the ram and move the metal locking tabs to the side by lifting upward slightly then moving each to their outside.
    • Pull the ram out toward the angle when the ram is sticking up at an angle when released.
  17. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 17, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 17, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm top screws holding the hard drive in place.
    • Pinch the top left corner with your finger and slide the harddrive out of its casing.
  18. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 18, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 18, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew two 5.0 mm screws holding SSD down to the motherboard on the right side of the board
    • Slide module out of protective casing to remove piece.
  19. ASUS TUF Gaming FX505DY Keyboard Replacement: stap 19, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 19, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement: stap 19, afbeelding 3 van 3
    • With a size 0 Phillips screwdriver, unscrew three center 5 mm screws securing the board in place.
    • Carefully lift the board and place in a safe area.
  20. ASUS TUF Gaming FX505DY Keyboard Replacement, Touchpad: stap 20, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Touchpad: stap 20, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Keyboard Replacement, Touchpad: stap 20, afbeelding 3 van 3
    • With a size 0 Phillips screwdriver, unscrew two 5 mm screws holding the trackpad in place located at the bottom of the trackpad.
    • Carefully unclip the connector base to remove the two touchpad cables.
    • Remove the trackpad by sliding forward and lifting up.
  21. ASUS TUF Gaming FX505DY Keyboard Replacement, Keyboard: stap 21, afbeelding 1 van 1
    • The keyboard is the entire body without any of the other parts attached. Do not try to remove the metal plate from the body.
Conclusie
Nick Pearcy
313 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Harley Spring 2023 Lid van IUPUI, Team 2-3, Harley Spring 2023
IUPUI-HARLEY-S23S2G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 90
Altijd: 1,277
