Inleiding
Use this guide for replacing the keyboard for your ASUS TUF Gaming FX505DY laptop. The keyboard is vital for operating any laptop for typing and the trackpad.
Only a Phillips size 1 screwdriver and a plastic pick (or a similar pointed object) are needed for this tutorial.
It is recommended that you keep track of the screws and remember where they should be when reassembling.
Make sure the laptop is turned off and unplugged before beginning the tutorial.
Wat je nodig hebt
Turn off the laptop.
Disconnect the charging cable.
Flip the laptop so the back is facing up.
Lift the speakers from the pegs holding them down. Use minimal force as to not break the pegs or the speakers.
With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
With a size 0 Phillips screwdriver, unscrew two 5 mm screws holding the trackpad in place located at the bottom of the trackpad.
Carefully unclip the connector base to remove the two touchpad cables.
Remove the trackpad by sliding forward and lifting up.
The keyboard is the entire body without any of the other parts attached. Do not try to remove the metal plate from the body.
