Ga door naar hoofdinhoud
ASUS TUF Gaming FX505DY Battery Replacement
Wat je nodig hebt
  1. ASUS TUF Gaming FX505DY Battery Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Battery Replacement: stap 2, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Battery Replacement: stap 3, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Battery Replacement: stap 4, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Battery Replacement, Battery: stap 5, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Battery Replacement, Battery: stap 5, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Battery Replacement, Battery: stap 5, afbeelding 3 van 3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Battery Replacement: stap 6, afbeelding 1 van 2 ASUS TUF Gaming FX505DY Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Battery Replacement: stap 7, afbeelding 1 van 3 ASUS TUF Gaming FX505DY Battery Replacement: stap 7, afbeelding 2 van 3 ASUS TUF Gaming FX505DY Battery Replacement: stap 7, afbeelding 3 van 3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Battery Replacement: stap 8, afbeelding 1 van 1
    • Lift the battery up out of the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ronald Brodeur
109 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 Leden
8 handleidingen geschreven
Één opmerking
What Is the serial number of the battery ?
Hector Garcia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 82
Altijd: 2,422
