Inleiding
Following this guide, you will be able to remove the external hard drive and replace it with a new one of your own. Make sure that you have a hard drive to replace the old one with prior to attempting this guide.
Wat je nodig hebt
Remove the six screws on the back of the laptop using a Phillips screwdriver.
Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
3 andere personen hebben deze handleiding voltooid.
