Ga door naar hoofdinhoud
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
Wat je nodig hebt
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: stap 1, afbeelding 1 van 1
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: stap 2, afbeelding 1 van 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: stap 3, afbeelding 1 van 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Logan Smith
783 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-3, Banghart Winter 2017 Lid van Cal Poly, Team 8-3, Banghart Winter 2017
CPSU-BANGHART-W17S8G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 969
