Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Gently pry the back hinge cover piece away from the device.
Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
Remove the RAM cover by lifting the screw cover and pulling away firmly.
Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
Remove the two screws from underneath the RAM cover.
Remove all of the screws from the bottom of the case.
If replacing the screen, remove the rubber feet to reveal two more screws.
Turn the laptop over and remove the screws as shown
Carefully pry the keyboard away using your spudger and the opening tools.
Remove tape and gently pull up on golden cap connectors to disconnect them.
Gently pull the white connector until it comes loose.
