Ga door naar hoofdinhoud
ASUS ROG G46VW Motherboard Replacement
Wat je nodig hebt
  1. ASUS ROG G46VW Motherboard Replacement, RAM: stap 1, afbeelding 1 van 2 ASUS ROG G46VW Motherboard Replacement, RAM: stap 1, afbeelding 2 van 2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Motherboard Replacement: stap 3, afbeelding 1 van 2 ASUS ROG G46VW Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Motherboard Replacement, Speaker Cover: stap 6, afbeelding 1 van 1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Motherboard Replacement, Keyboard: stap 8, afbeelding 1 van 1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Motherboard Replacement: stap 12, afbeelding 1 van 2 ASUS ROG G46VW Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Motherboard Replacement, Screen: stap 13, afbeelding 1 van 2 ASUS ROG G46VW Motherboard Replacement, Screen: stap 13, afbeelding 2 van 2
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Gently pull the white connector until it comes loose.
  17. ASUS ROG G46VW Motherboard Replacement, Indicator Lights: stap 17, afbeelding 1 van 1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  18. ASUS ROG G46VW Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  19. ASUS ROG G46VW Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
  20. ASUS ROG G46VW Motherboard Replacement, Motherboard: stap 20, afbeelding 1 van 1
    • Locate and remove the screws.
    • Removing the screws allows you to lift up the motherboard
  21. ASUS ROG G46VW Motherboard Replacement: stap 21, afbeelding 1 van 1
    • After lifting the motherboard up you can replace any component on it, such as the fans.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,958
