Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
Remove the RAM cover by lifting the screw cover and pulling away firmly.
Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
Gently pry the back hinge cover piece away from the device.
Remove the two screws from underneath the RAM cover.
Remove all of the screws from the bottom of the case.
If replacing the screen, remove the rubber feet to reveal two more screws.
Turn the laptop over and remove the screws as shown
Carefully pry the keyboard away using your spudger and the opening tools.
With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
Pull the plastic white housing piece away from the case.
Locate the flat LED cable that connects the lights to the motherboard.
Flip the black cover upwards before pulling on the cable.
Repeat for the other connector piece.
