Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Lift the screw cover and remove the screw using a Phillips #0 screwdriver. Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. Remove the RAM cover by lifting the screw cover and pulling away firmly.
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. Push outwards on the clips to release the RAM stick. The stick should pop up at an angle. Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. Pull out the RAM stick carefully.
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. Repeat steps 3-4 to remove the second RAM stick.
    • Repeat steps 3-4 to remove the second RAM stick.
  6. Gently pry the back hinge cover piece away from the device.
    • Gently pry the back hinge cover piece away from the device.
  7. Disconnect the speaker cable from the motherboard.
    • Disconnect the speaker cable from the motherboard.
  8. Remove the two screws from underneath the RAM cover.
    • Remove the two screws from underneath the RAM cover.
  9. Remove all of the screws from the bottom of the case.
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. Turn the laptop over and remove the screws as shown
    • Turn the laptop over and remove the screws as shown
  11. Carefully pry the keyboard away using your spudger and the opening tools.
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. Detach the ribbon cable by releasing the clip Detach the ribbon cable by releasing the clip
    • Detach the ribbon cable by releasing the clip
  13. With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  14. Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  15. Locate the flat LED cable that connects the lights to the motherboard.
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
Conclusie
Nicolas Catano
104 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 152
