Ga door naar hoofdinhoud
ASUS R554L Battery Replacement
Wat je nodig hebt
  1. ASUS R554L Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: stap 2, afbeelding 1 van 3 ASUS R554L Battery Replacement: stap 2, afbeelding 2 van 3 ASUS R554L Battery Replacement: stap 2, afbeelding 3 van 3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: stap 3, afbeelding 1 van 3 ASUS R554L Battery Replacement: stap 3, afbeelding 2 van 3 ASUS R554L Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: stap 4, afbeelding 1 van 3 ASUS R554L Battery Replacement: stap 4, afbeelding 2 van 3 ASUS R554L Battery Replacement: stap 4, afbeelding 3 van 3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: stap 5, afbeelding 1 van 3 ASUS R554L Battery Replacement: stap 5, afbeelding 2 van 3 ASUS R554L Battery Replacement: stap 5, afbeelding 3 van 3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: stap 6, afbeelding 1 van 2 ASUS R554L Battery Replacement: stap 6, afbeelding 2 van 2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Conclusie
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
Één andere persoon heeft deze handleiding voltooid.
Joshua Chavez
160 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 351
Altijd: 6,093
