Ga door naar hoofdinhoud
ASUS Q536F Motherboard Replacement
Wat je nodig hebt
  1. ASUS Q536F Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Motherboard Replacement, Battery: stap 2, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement, Battery: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
    • Detach the battery cable from the motherboard using a pair of tweezers.
  3. ASUS Q536F Motherboard Replacement: stap 3, afbeelding 1 van 3 ASUS Q536F Motherboard Replacement: stap 3, afbeelding 2 van 3 ASUS Q536F Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Unhinge the fan cable using your fingers or a pair of tweezers.
    • Remove the battery from its slot.
    • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
  4. ASUS Q536F Motherboard Replacement, Fan: stap 4, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement, Fan: stap 4, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
    • Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
    • Warped Screw
    • Heatsink shown has warped screw, so unable to remove
  5. ASUS Q536F Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Disconnect white and black antennae cables.
    • Using tweezers for this would be helpful.
  6. ASUS Q536F Motherboard Replacement: stap 6, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Disconnect fan cables pulling outwards as shown.
  7. ASUS Q536F Motherboard Replacement: stap 7, afbeelding 1 van 3 ASUS Q536F Motherboard Replacement: stap 7, afbeelding 2 van 3 ASUS Q536F Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
    • The fan can be removed without removing the heatsink, although it may be easier to remove.
  8. ASUS Q536F Motherboard Replacement, Hard Drive: stap 8, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement, Hard Drive: stap 8, afbeelding 2 van 2
    • Disconnect the white ribbon cable from the connection lever using a Jimmy.
  9. ASUS Q536F Motherboard Replacement: stap 9, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Using the Jimmy, lift the hard drive out of its slot.
  10. ASUS Q536F Motherboard Replacement, SSD: stap 10, afbeelding 1 van 1
    • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
  11. ASUS Q536F Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Pull the SSD out of its slot.
  12. ASUS Q536F Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 ASUS Q536F Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
  13. ASUS Q536F Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Using a Jimmy, pull up on the power cable.
  14. ASUS Q536F Motherboard Replacement: stap 14, afbeelding 1 van 3 ASUS Q536F Motherboard Replacement: stap 14, afbeelding 2 van 3 ASUS Q536F Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Using the Jimmy, lift up on both ribbon cable clamps, releasing the connection point, just like in step 8.
Conclusie
Adra Ledward
557 Reputatie
5 handleidingen geschreven
Gateway, Team 88-8, Gonzalez Fall 2023 Lid van Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 614
