Ga door naar hoofdinhoud
ASUS Q400A-BHI7N03 Screen Replacement
Wat je nodig hebt
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: stap 2, afbeelding 1 van 1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: stap 3, afbeelding 1 van 1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: stap 5, afbeelding 1 van 1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: stap 6, afbeelding 1 van 1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wan Ahmad Aiman
403 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Harley Fall 2018 Lid van IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 Leden
Één opmerking
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 598
