Ga door naar hoofdinhoud
ASUS Q400A-BHI7N03 Power Jack Replacement
Wat je nodig hebt
  1. ASUS Q400A-BHI7N03 Power Jack Replacement, Power Jack: stap 1, afbeelding 1 van 1
    • Flip laptop over with the battery facing toward you.
    • Slide both tabs with the lock/unlock symbol, near the battery on the right of the notebook, to the unlock position.
    • Grab the top edge of the battery & lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the one black 8mm Phillips #0 screw.
    • Lift and remove the bottom cover panel using the plastic opening tool.
  3. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 8mm Phillips #0 screws.
    • Lift and remove the drive.
  4. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the single silver 8mm Phillips #0 screw.
    • Remove the three 8mm Phillips #0 screws.
  5. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the seven black 8mm Phillips #0 screws around the perimeter.
    • Remove the two silver 8mm Phillips #0 screws that are under the battery.
  6. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 6, afbeelding 1 van 1
    • Flip the device right-side up and pry up the keyboard and touchpad gently using both hands.
  7. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 7, afbeelding 1 van 1
    • Release the ZIF (zero insertion force) connector using a plastic spudger.
    • Remove the ribbon cable by hand from the ZIF connector.
    • Do not use too much force when releasing the ZIF connector.
  8. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 8, afbeelding 1 van 2 ASUS Q400A-BHI7N03 Power Jack Replacement: stap 8, afbeelding 2 van 2
    • Remove the two remaining ribbon cables as described in Step 7.
  9. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Unscrew the two black 8mm Phillips #0 screws.
    • Firmly grasp each antenna head with a pair of blunt tweezers and detach it by lifting up straight.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
  10. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 10, afbeelding 1 van 1
    • Remove the five black 8mm Phillips #0 screws.
  11. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 11, afbeelding 1 van 1
    • Firmly grab the optical drive and remove it by sliding it out.
  12. ASUS Q400A-BHI7N03 Power Jack Replacement: stap 12, afbeelding 1 van 2 ASUS Q400A-BHI7N03 Power Jack Replacement: stap 12, afbeelding 2 van 2
    • Lift the motherboard gently to completely remove this component from the device.
    • Detach Audio Cable gently by hand and you have now access to replace the power jack.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wan Ahmad Aiman
403 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Harley Fall 2018 Lid van IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 902
