Ga door naar hoofdinhoud
ASUS Q400A-BHI7N03 Optical Drive Replacement
Wat je nodig hebt
  1. ASUS Q400A-BHI7N03 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 3, afbeelding 1 van 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
  4. ASUS Q400A-BHI7N03 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Locate and remove the 8mm PH0 screw near the middle of the laptop.
  5. ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 5, afbeelding 1 van 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Use a metal opening tool to remove the L-shaped, plastic cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 6, afbeelding 1 van 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: stap 6, afbeelding 2 van 2
    • On the left side of the section, there is a metal tab. Using a metal opening tool, push the tab as far as possible to the left.
    • Only push on the metal tab so you do not damage the surrounding plastic.
    • Once the optical drive is sticking out of the left side of the laptop, slide it smoothly out of its slot.
Conclusie
Matthew Gold
401 Reputatie
4 handleidingen geschreven
UC Davis, Team 1-4, Rodger Winter 2017 Lid van UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 535
