Ga door naar hoofdinhoud
ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement
Wat je nodig hebt
  1. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 2, afbeelding 1 van 2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 3, afbeelding 1 van 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 5, afbeelding 1 van 2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 5, afbeelding 2 van 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Power & Volume Button PCB Board: stap 6, afbeelding 1 van 1
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  7. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 7, afbeelding 1 van 3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 7, afbeelding 2 van 3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: stap 7, afbeelding 3 van 3
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
Conclusie
Scott Santiago
534 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 648
