Inleiding
This guide will show how to replace the motherboard of the ASUS Portable AiO PT2001.
Wat je nodig hebt
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Peel off the tape attaching the metal enclosure to the heat sink.
Lift the metal enclosure off of the motherboard.
The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
Remove the tape attached to the heat sink and the metal enclosure.
Lift the metal enclosure off.
Flip up the locking mechanism and disconnect the three cables using a nylon spudger.
Disconnect two more cables by pulling back on the cable using a nylon spudger.
Disconnect the battery cable by pulling up on the black connector.
Één andere persoon heeft deze handleiding voltooid.
