Inleiding
This guide will show how to remove the back panel of the ASUS Portable AiO PT2001. Removing this panel is required to access the internal components.
Wat je nodig hebt
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
4 andere personen hebben deze handleiding voltooid.
