Ga door naar hoofdinhoud
ASUS Padfone X mini Station Speaker Replacement
Wat je nodig hebt
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: stap 2, afbeelding 1 van 2 ASUS Padfone X mini Station Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: stap 3, afbeelding 1 van 3 ASUS Padfone X mini Station Speaker Replacement: stap 3, afbeelding 2 van 3 ASUS Padfone X mini Station Speaker Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: stap 5, afbeelding 1 van 3 ASUS Padfone X mini Station Speaker Replacement: stap 5, afbeelding 2 van 3 ASUS Padfone X mini Station Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: stap 6, afbeelding 1 van 2 ASUS Padfone X mini Station Speaker Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to detach the connecter from the motherboard.
Conclusie
Alexzander Pastore
389 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 160
