Ga door naar hoofdinhoud
ASUS Padfone X mini Station Front Camera Replacement
Wat je nodig hebt
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: stap 3, afbeelding 1 van 1
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: stap 5, afbeelding 1 van 1
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: stap 6, afbeelding 1 van 2 ASUS Padfone X mini Station Front Camera Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to detach the camera from the motherboard.
Conclusie
Nuri Syahirah Mohd Safian
133 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
3 Leden
4 handleidingen geschreven
Één opmerking
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 168
