Onderdelen
Geen onderdelen nodig.
  1. Using the plastic opening tools, insert it into the edge and pry open. Use hands to help pull the back off from the front if needed.
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. Locate CON2002 Check water indicator on USB Charging Port
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Locate and remove three Phillips screws
    • Locate and remove three Phillips screws
  5. Use a pair of tweezers to disconnect E893821
    • Use a pair of tweezers to disconnect E893821
Conclusie
4 andere personen hebben deze handleiding voltooid.
Daniel
308 Reputatie
2 handleidingen geschreven
USF Tampa, Team 7-4, Leahy Fall 2014 Lid van USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Leden
8 handleidingen geschreven
Één commentaar
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 17
Altijd: 2,336
