Wat je nodig hebt
Using the plastic opening tools, insert it into the edge and pry open.
Use hands to help pull the back off from the front if needed.
Locate 4600mAh Battery
Locate (+) and (-) battery terminals
Trace black, white, red, and yellow wires to connection on motherboard
Remove protective plastic cover with tweezers
Remove (4) screws
Gently pry battery off glued surface
Use of a plastic opening tools and a spudger are necessary
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
where can i find a battery for that station pls?
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
