Ga door naar hoofdinhoud
ASUS PadFone X Station Battery Replacement
Wat je nodig hebt
  1. ASUS PadFone X Station Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 ASUS PadFone X Station Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Battery Replacement, Finding the Battery: stap 2, afbeelding 1 van 1
    • Locate 4600mAh Battery
  3. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: stap 3, afbeelding 1 van 2 ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: stap 3, afbeelding 2 van 2
    • Locate (+) and (-) battery terminals
    • Trace black, white, red, and yellow wires to connection on motherboard
    • Remove protective plastic cover with tweezers
  4. ASUS PadFone X Station Battery Replacement, Disconnecting the Ribbon: stap 4, afbeelding 1 van 1
    • Disconnect connect ribbon by gently pulling with fingers
    • Ensure the ribbon does not touch metallic items (This may short out battery and cause an explosion)
  5. ASUS PadFone X Station Battery Replacement, Removing the Screws: stap 5, afbeelding 1 van 2 ASUS PadFone X Station Battery Replacement, Removing the Screws: stap 5, afbeelding 2 van 2
    • Remove (4) screws
  6. ASUS PadFone X Station Battery Replacement, Taking out the Battery: stap 6, afbeelding 1 van 3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: stap 6, afbeelding 2 van 3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: stap 6, afbeelding 3 van 3
    • Gently pry battery off glued surface
    • Use of a plastic opening tools and a spudger are necessary
Conclusie
5 andere personen hebben deze handleiding voltooid.
Paul Wagner
545 Reputatie
2 handleidingen geschreven
USF Tampa, Team 7-4, Leahy Fall 2014 Lid van USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Leden
8 handleidingen geschreven
3 opmerkingen
where can i find a battery for that station pls?
francidorio - Antwoord
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
calejanmm - Antwoord
The proper battery for this unit is C11P1323.
acg - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 3,648
