Ga door naar hoofdinhoud
ASUS PadFone X Rear Facing Camera Replacement
Wat je nodig hebt
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: stap 1, afbeelding 1 van 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: stap 1, afbeelding 2 van 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: stap 2, afbeelding 1 van 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: stap 2, afbeelding 2 van 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: stap 2, afbeelding 3 van 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: stap 3, afbeelding 1 van 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: stap 3, afbeelding 2 van 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: stap 4, afbeelding 1 van 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: stap 5, afbeelding 1 van 1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: stap 6, afbeelding 1 van 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
Conclusie
nestor
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 8-4, Leahy Fall 2014 Lid van USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 519
