Ga door naar hoofdinhoud
ASUS PadFone X Power and Volume Buttons Replacement
Wat je nodig hebt
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: stap 1, afbeelding 1 van 1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: stap 3, afbeelding 1 van 1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: stap 5, afbeelding 1 van 1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: stap 6, afbeelding 1 van 1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
Conclusie
Madeline Dement
114 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-1, Baechle Spring 2017 Lid van IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 289
