Ga door naar hoofdinhoud
ASUS PadFone X Battery Replacement
Wat je nodig hebt
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: stap 1, afbeelding 1 van 2 ASUS PadFone X Battery Replacement, Remove the back panel.: stap 1, afbeelding 2 van 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: stap 2, afbeelding 1 van 2 ASUS PadFone X Battery Replacement, Remove the screws.: stap 2, afbeelding 2 van 2
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: stap 3, afbeelding 1 van 2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: stap 3, afbeelding 2 van 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: stap 4, afbeelding 1 van 2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: stap 4, afbeelding 2 van 2
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: stap 5, afbeelding 1 van 2 ASUS PadFone X Battery Replacement, Remove the battery.: stap 5, afbeelding 2 van 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
John Kue
379 Reputatie
2 handleidingen geschreven
USF Tampa, Team 8-4, Leahy Fall 2014 Lid van USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 5,136
