Inleiding
If your optical drive is damaged or if you wish to upgrade it, this guide will show you how to replace the optical drive. A metal spudger will be a tool used for this guide.
Onderdelen
Geen onderdelen nodig.
  1. Push the battery latch. Push the battery latch.
    • Push the battery latch.
  2. Keep the battery latch held while you remove the battery.
    • Keep the battery latch held while you remove the battery.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove the one screw above the battery port.
    • Remove the one screw above the battery port.
    • This device was missing its screws on the back cover when we received the device. As a result, we do not know what head type the screws are, along with their lengths.
  5. Use a metal spudger to dislodge the optical drive from the connector.
    • Use a metal spudger to dislodge the optical drive from the connector.
  6. Pull out the optical drive.
    • Pull out the optical drive.
Conclusie
Ruben Lopez
399 Reputatie
4 handleidingen geschreven
IUPUI, Team S1-G4, Baechle Fall 2018 Lid van IUPUI, Team S1-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G4
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 8
Altijd: 62
