Ga door naar hoofdinhoud
ASUS K200MA-DS01T Trackpad Replacement
Wat je nodig hebt
  1. ASUS K200MA-DS01T Trackpad Replacement, Back Panel: stap 1, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Trackpad Replacement: stap 2, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Trackpad Replacement: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Trackpad Replacement: stap 4, afbeelding 1 van 3 ASUS K200MA-DS01T Trackpad Replacement: stap 4, afbeelding 2 van 3 ASUS K200MA-DS01T Trackpad Replacement: stap 4, afbeelding 3 van 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Trackpad Replacement, Keyboard: stap 5, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Trackpad Replacement: stap 6, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement: stap 6, afbeelding 2 van 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Trackpad Replacement, Track Pad: stap 7, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement, Track Pad: stap 7, afbeelding 2 van 2
    • Lift the keyboard connector from the keyboard.
  8. ASUS K200MA-DS01T Trackpad Replacement: stap 8, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement: stap 8, afbeelding 2 van 2
    • Lift the foil sheet.
  9. ASUS K200MA-DS01T Trackpad Replacement: stap 9, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement: stap 9, afbeelding 2 van 2
    • Eight 3 mm screws using Phillips screwdriver.
    • Be sure to remove the screw underneath the keyboard connector.
  10. ASUS K200MA-DS01T Trackpad Replacement: stap 10, afbeelding 1 van 1
    • Two 2 mm screws using a Phillips #00 screwdriver.
  11. ASUS K200MA-DS01T Trackpad Replacement: stap 11, afbeelding 1 van 2 ASUS K200MA-DS01T Trackpad Replacement: stap 11, afbeelding 2 van 2
    • Using a plastic spudger, remove the metal plate.
  12. ASUS K200MA-DS01T Trackpad Replacement: stap 12, afbeelding 1 van 3 ASUS K200MA-DS01T Trackpad Replacement: stap 12, afbeelding 2 van 3 ASUS K200MA-DS01T Trackpad Replacement: stap 12, afbeelding 3 van 3
    • Flip the keyboard over.
    • Using a plastic spudger, pry the track pad off the plastic piece underneath.
    • Don't be afraid to use some force in this step because the track pad and the plastic piece are glued together.
Conclusie
Terrinda
526 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Lid van CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 106
