Ga door naar hoofdinhoud
ASUS K200MA-DS01T Hard Drive Replacement
Wat je nodig hebt
  1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Hard Drive Replacement: stap 2, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Hard Drive Replacement: stap 4, afbeelding 1 van 3 ASUS K200MA-DS01T Hard Drive Replacement: stap 4, afbeelding 2 van 3 ASUS K200MA-DS01T Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: stap 5, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Hard Drive Replacement: stap 6, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Hard Drive Replacement, Battery: stap 7, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement, Battery: stap 7, afbeelding 2 van 2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Hard Drive Replacement: stap 8, afbeelding 1 van 3 ASUS K200MA-DS01T Hard Drive Replacement: stap 8, afbeelding 2 van 3 ASUS K200MA-DS01T Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Hard Drive Replacement, Fan: stap 9, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement, Fan: stap 9, afbeelding 2 van 2
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Hard Drive Replacement: stap 11, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement: stap 11, afbeelding 2 van 2
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Hard Drive Replacement: stap 12, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement: stap 12, afbeelding 2 van 2
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
  13. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: stap 13, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: stap 13, afbeelding 2 van 2
    • Four 4mm Phillips screws using a Phillips #0 screwdriver.
  14. ASUS K200MA-DS01T Hard Drive Replacement: stap 14, afbeelding 1 van 2 ASUS K200MA-DS01T Hard Drive Replacement: stap 14, afbeelding 2 van 2
    • Remove by sliding hard driving right and away from the computer using the tag on the right side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Terrinda
526 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Lid van CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 493
