Inleiding
This guide will explain the process of installing a new screen, or replacing pre-existing screen. This process is more complicated than the other guides. The process to fix the screen is far more complicated and requires a professional. It is recommended to replace the screen should problems arise.
Wat je nodig hebt
Use a Jimmy to separate the outer panel of the monitor from the bezel. This is accomplished by wedging the tool in the small crease and pulling apart.
To remove the bezel and gain access to the LCD screen, place your thumbs over the two holes where the screws used to be, and apply pressure.
Then, simultaneously apply pressure and push the upwards and the bezel will side off.
Once released, the bezel will lift off freely from the face of the screen.
To reassemble your ASUS F555UA-EH71 laptop , follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
