Ga door naar hoofdinhoud
ASUS E210MA-TB.CL464BK Battery Replacement
Wat je nodig hebt
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: stap 1, afbeelding 1 van 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: stap 1, afbeelding 2 van 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: stap 2, afbeelding 1 van 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: stap 3, afbeelding 1 van 2 ASUS E210MA-TB.CL464BK Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: stap 4, afbeelding 1 van 2 ASUS E210MA-TB.CL464BK Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: stap 5, afbeelding 1 van 2 ASUS E210MA-TB.CL464BK Battery Replacement: stap 5, afbeelding 2 van 2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift up and remove the battery.
Conclusie
John Hutchins
763 Reputatie
5 handleidingen geschreven
Gateway, Team 73-6, Gonzalez Spring 2023 Lid van Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 87
Altijd: 909
