Inleiding
If you find the need to replace your motherboard, fan or RAM, then follow this guide. Be sure to remove the Keyboard Module, DVD Drive, and Hard Drive before removing the motherboard.
Wat je nodig hebt
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
Locate the Network Interface Card (NIC) on the motherboard.
Gently disconnect the white and black wires by pulling it off of the NIC card. These wires should come off easy.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
Disconnect the three cables attached to the motherboard.
The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
