Ga door naar hoofdinhoud
ASUS Chromebook C424MA-DH48F Speakers Replacement
Wat je nodig hebt
  1. ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: stap 1, afbeelding 1 van 2 ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 3 van 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: stap 3, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: stap 3, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: stap 3, afbeelding 3 van 3
    • Use an opening tool or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
  4. ASUS Chromebook C424MA-DH48F Speakers Replacement: stap 4, afbeelding 1 van 1
    • Lift the right speaker up and out of the chassis, with care not to strain the connected cable.
  5. ASUS Chromebook C424MA-DH48F Speakers Replacement: stap 5, afbeelding 1 van 1
    • Unseat the speaker wires from the lower side of the battery.
  6. ASUS Chromebook C424MA-DH48F Speakers Replacement: stap 6, afbeelding 1 van 1
    • Lift the left speaker up and out of the chassis.
Conclusie
Anthony Wink
401 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 28
