Ga door naar hoofdinhoud
ASUS Chromebook C300MA-DH01 Battery Replacement
Wat je nodig hebt
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 2, afbeelding 1 van 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 2, afbeelding 2 van 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 3, afbeelding 1 van 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 3, afbeelding 2 van 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 3, afbeelding 3 van 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 4, afbeelding 1 van 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 4, afbeelding 2 van 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 4, afbeelding 3 van 3
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 5, afbeelding 1 van 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 5, afbeelding 2 van 2
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
Conclusie
amer khalil
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G5, Passmore Fall 2017 Lid van USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 203
